VPN
- VPN
VPN
14-05-2014 1:06 PM
Dear community - grateful if anyone can help.
I have recently moved to Plusnet and I often work from home. I've been experiencing difficulty connecting to work via a VPN and I've told that it's pro ably something to do with the VPN port I'm trying g to use. Does anyone have any ideas how I can check this?
Many thanks
NickMA
Many thanks
NickMA
Message 1 of 7
(1,127 Views)
6 REPLIES 6
Re: VPN
14-05-2014 1:13 PM
Have you tried disabling the Plusnet firewall? https://portal.plus.net/my.html?action=firewall
Note you need to disconnect/connect after changing the setting.
Message 2 of 7
(769 Views)
Re: VPN
14-05-2014 2:25 PM
Thanks Jelv. Just checked and the Plusnet firewall is switched off.
Message 3 of 7
(769 Views)
Re: VPN
14-05-2014 2:37 PM
Any other thoughts gratefully received as I'm struggling to get some work done. Not sure why when I was with Talk Talk I didn't have this issue.
Message 4 of 7
(769 Views)
Re: VPN
14-05-2014 2:39 PM
http://npr.me.uk/vpnissue.html might help if you are using the Plusnet supplied router.
Message 5 of 7
(769 Views)
Re: VPN
14-05-2014 4:47 PM
I do have a Plusnet router Technicolor a TG582N and I've followed the instructions but it's not accepting my user name and password, which otherwise works fine when I need to add a new wireless devices to the router. I've followed the Plusnet user name and password that came with the router and tried several times now. Is there a way to get this to work or should I simply buy a new router?
Message 6 of 7
(769 Views)
Re: VPN
14-05-2014 4:51 PM
The username is 'admin' and the password is CPXXXXXXXXXXXXX all case sensitive for the router access. Got this correct? Tried another browser/computer?
Message 7 of 7
(769 Views)
