VPN
pleasenlighten
VPN
Anone use VPN . If so which product... is the Tor one better than for example Hotspotshield and are there any disadvantages to using a VPN. Does it slow down surfing?
Thanks Shocked
1 REPLY
Fixes: 127
Re: VPN
Any VPN will add latency to your connection, TOR probably more than a paid for VPN.
I use privateinternetaccess and have had no issues.
Will Moderate For Thanks
