VPN traffic queue UDP 443
- VPN traffic queue UDP 443
07-09-2015 11:29 AM
Hi, can someone confirm if UDP 443 is marked correctly as a VPN category?
Message 1 of 2
(569 Views)
1 REPLY 1
Re: VPN traffic queue UDP 443
07-09-2015 2:46 PM
The traffic management system doesn't just mark based on ports, it identifies the traffic signature and applies the management based on that.
There's a guide here which should help identify if the traffic is marked correctly. http://community.plus.net/library/faults/using-wireshark-for-data-capture/
Message 2 of 2
(368 Views)
