VPN server on DD-WRT
extra
I'm looking at getting a router so that I can use my router as a VPN server.
I was thinking about putting DD-WRT on an Asus RT-n55u or RT-n66u... would that be compaitble with Plusnet Fibre broadband?
Cheers
1 REPLY
Fixes: 62
Re: VPN server on DD-WRT
I'm not sure if DD-WRT is compatible with those routers but the routers themselves should be fine, yes.
If you have a dig around I'm sure you'll find posts from others using the RT-n55u Smiley
 Adam Walker
