VPN problem
- VPN problem
VPN problem
06-04-2008 6:08 PM
I'm trying to setup an incoming VPN connection with Windows Vista, but port 445 isn't being seen externally (grc.com, sheildsup).
I've set my router to forward 445 UDP/TCP to my PC.
To check the forwarding was working, I also temporarily opened port 1, which is being seen externally.
Plusnet firewall setting is off.
Vista firewall is off.
Any ideas?
Dave
Any ideas?
Dave
Message 1 of 4
(879 Views)
3 REPLIES 3
Re: VPN problem
06-04-2008 6:47 PM
A quick confirmation check of your account shows no reason why.
Can you advise what type of VPN you are using, as there is normally more than just opening port 445 for most VPNs.
Often VPNs work on other protocols, which many routers don't deal with too good (even in DMZ) or more than just the one port.
Message 2 of 4
(283 Views)
Re: VPN problem
06-04-2008 7:35 PM
I've been trying to set up a VPN from a new laptop on our network.
I can VPN into the server from any other machine but this one.
I therefore have to conclude that it's something installed on the laptop that is blocking access.
Is there any other security package installed on your machine that could be blocking ports.
Message 3 of 4
(283 Views)
Re: VPN problem
06-04-2008 10:11 PM
I have no other secuirty firewall style products installed.
I changed my router to point to an XP machine with 445, 446 and 1, same problem, 445 isn't being seen externally, but 1 and 446 are.
After a bit more reading, it turns out I might need UDP 1723 open instead, I'll be trying that a bit later when my VPN guinea pig comes back online.
Dave
Dave
Message 4 of 4
(283 Views)
