VPN on technicolor TG582n wireless fibre router
- VPN on technicolor TG582n wireless fibre router
17-07-2013 9:16 PM
ordered upgrade to fibre because support said this router was capable of terminating VPN`s , but I cant find the page to set it up. has anyone managed to find the correct place?
Cheers
Cheers
Message 1 of 2
(1,044 Views)
1 REPLY 1
Re: VPN on technicolor TG582n wireless fibre router
18-07-2013 8:22 AM
If you mean acting as an endpoint for a VPN tunnel, then NO, I'm afraid the TG582n won't do that. It WILL do VPN passthrough if you are running a VPN client on an attached PC for instance.
Message 2 of 2
(317 Views)
