VPN fine for 9 months, stopped working Jan.
- VPN fine for 9 months, stopped working Jan.
01-03-2016 3:57 PM
First of all I will try the steps listed by Mister in another topic.
VPN connection through BT Mobile Express (owners of Plusnet) has stopped working over the last month.
My IT guys state "this is an issue with Plusnet and BT - the user connected via the broadband line here , so GRAS works - the user needs to speak direct with Plusnet to advise how they are going to resolve the issue.One of the contractors here had the same issue and he had to change his connection settings in his portal - this would be somethingt that Plusnet should talk the user through"
Plusnet won't have anything to do with 'supporting VPN' they said it is not within their policy and their first line supervisors told me to research it myself.......
I've raised a complaint ticket.
Any help, grateful,
I have no idea why it worked fine for months now it doesn't work.
I do get a 'green, connection available' on the BT Mobile Express client, but it times out after failing to find a connection. I can't access the internet either (before I can normally browse google etc without signing on to VPN.
Re: VPN fine for 9 months, stopped working Jan.
01-03-2016 4:22 PM
Thank you for getting in touch with us via the forum pages. Unfortunately we do not support VPN and any issues you would have to relate to your supplier for the VPN service.
One think I can advise you to check though the member centre is if you broadband firewall is disabled
02-03-2016 7:04 PM
personally think its a joke that VPN isn't supported. Note: it is not just the VPN connection. I have no internet connection through my work laptop (Which is said to be down to a change of settings between Plusnet and BT)
08-03-2016 9:12 AM
Which model Plusnet router do you have ?
Assuming the laptop is running windows, can you open a cmd window and post the results of an ipconfig/all command and maybe also a tracert BBC.CO.uk
Edit: just seen this new thread here http://community.plus.net/forum/index.php/topic,149139.0.html
Seems like a very similar issue, I've posted a link in that thread
08-03-2016 8:42 PM
I've posted in the Fibre forum, but want to add my voice to this thread - I truly believe Plusnet have changed something that is causing IPSEC connectivity problems.
They've allegedly changed some settings on my config too - but it's not helped.
Kevin
09-03-2016 10:16 AM
Quote from: cohlas VPN connection through BT Mobile Express (owners of Plusnet) has stopped working over the last month.
Quote from: cohlas Plusnet won't have anything to do with 'supporting VPN' they said it is not within their policy and their first line supervisors told me to research it myself.......
Apologies for the hassle.
We've identified an issue with the routing of your circuit that I suspect was the cause of the issue. I've made some changes to your account and just kicked your connection. All being well, things should be working again now?
Quote from: kmarchant Ditto - I've reported similar problem to support as well. I'm using Checkpoint Endpoint Security IPSEC VPN. Worked fine for years - but I started getting gateway not responding a week or two ago. Works fine from other broadband providers and using tethering on my iPhone.
Looks like you're in the same boat. I've made the same changes to your account too so shout up if you're still experiencing problems.
09-03-2016 10:45 AM
Thanks Bob !
11-03-2016 12:29 PM
11-03-2016 3:03 PM
22-03-2016 7:21 AM
Am working from home today and really could do with some urgent help for my circuit too please (if possible)?
Otherwise I'll be using my tethered mobile all day
Many thanks
22-03-2016 10:26 AM
We think this issue may be arising due to how BT MX handle the IP range applied to your connection. Have you raised a support ticket with them directly via your IT Helpdesk? It may help us get this resolved for other customers affected too.
Steve
22-03-2016 11:51 AM
I raised a ticket with my company IT Helpdesk and they've passed it to the networks team. The 1st line did say they've have other Plusnet users with the same issue but no resolution.
Happy to pass any details back to our IT Helpdesk that will help others in the same situation. I can put together an email but will need a summary of what the problem is, how it's fixed and how a Plusnet user goes about getting it resolved i.e. via Plusnet to raise a ticket or via this Community forum? Happy to tick-tack some wording if you want to directly message me via email? I'd be interested myself in what the issue was and how it's resolved, am a network techie myself so should understand the technical reply. In the spirit of the community forum, happy to help others if needed
I did contact the BT Helpdesk but their 1st line support was next to useless, when I asked him for details of the DNS Name/URL/IP address of the VPN concentrator, he paused a while and said "ah here it is: 127.0.0.1"
Again, many thanks for your reply. Really appreciated Steve.
mav:quote
22-03-2016 12:17 PM
Steve
15-04-2016 3:22 PM
Hi, I'm having exactly the same issue, I've been able to use work VPN for a number of years but access recently stopped. Like kmarchant I've reported the problem to support (was told there was nothing they could do) and I'm using Checkpoint Endpoint Security IPSEC VPN. I can connect without issue on other broadband providers and works with my phone as a tethered hotspot. Any help you could give me would be great as I can no longer work from my home.
15-04-2016 3:40 PM
