VPN fine for 9 months, stopped working Jan.
Robson
Re: VPN fine for 9 months, stopped working Jan.
Hi scrookes,
I've been connecting succesfully to a Co-OP VPN (BT Mobile Express) for 7 months but now believe I have the same issue as mentioned above.  I've sent you a private message with required details.  Would really appreciate it if you could apply the fix to my account too.
scrookes
Fixes: 4
Hi @Robson,
I'll reply to your PM shortly. Just reading the ticket raised.
bigsyd
Hi so glad I have found this post, my vpn keeps disconnecting,I am a recent mover from sky and never had a problem before
i have paid for another test vpn to see if it helped but that one also keeps disconnecting
hope you can help
Rsebrie
The VPN is use is ProXPN
It works fine for me. I load it up and say I'm in New York, and thus can then watch Crackle all day long.
ProXPN. Works a treat..
Thought I'd share, in case you wanted to give it ago and see if that works for you.
(EDIT - scratch that, mine also doesn't work. Crackle with my vpn running now refuses to load, and gives me the generic "This page can't be displayed" response.)
its probably because I have a Static ip and my VPN can't change that IDK.
Glad I checked
kevinsneddon
Hi Bob (or anyone available),
I have the same issue at home when my wife needs to work using Cisco VPN. It reports a connection Timeout or Authentication Error.  I was extremely disappointed when I used the Customer Portal chat mechanism to talk to an Agent today and describe the issue, only to be told; "Sorry we cannot support VPN through this portal, please use the Forums".
I have already explained to the Agent that if my wife and I cannot work from home using VPN over PlusNet, we would need to cancel our contract and service with immediate effect - it is not fit for purpose.
Is there a solution to this?
scrookes
Fixes: 4
@kevinsneddon
Can you private message me the following details please and I will take a look for you:
username:
client software and version:
endpoint ip:
where you work:
Sorry to ask so many questions but we do need to understand where the VPN is routing so we can investigate.
scrookes
Fixes: 4
Thanks for taking my call.  Seems my PM reply was sent twice for some reason.  Let me know how you get on following the reboot please.  I'm back in the office on Friday if it still doesn't work.  I'll take a further look then.
pb1
Hi @scrookes and @bobpullen
I think I also have this problem with VPN connectivity - it used to work ok but now I can't connect.
I have PM'd you with the full details. Hopefully you can help resolve.
Thanks.
bobpullen
Fixes: 316
@pb1, I've replied to your PM.
pb1
Many thanks @bobpullen. Problem resolved.
smcc
I have the same problem as mentioned many times here. I have been connecting successfully via VPN using BT Mobile Express with a wired connection, however this has suddenly stopped working for no apparent reason, with error message 12275. Please help!
Robson
you need a static ip address and the problem disappears.
smcc
So what is a static ip address and how do I get one?Huh
Robson
Go to member settings.  Click add-ons.  It costs £5.  That solved the problem for me.
Mustrum
Fixes: 77
You should not need to purchase a static IP to solve the problem. Doing so will alter the way your connection routes, but contacting @bobpullen or @scrookes will help diagnose the issue, and hopefully help others.
Let them know the info they have already asked, hopefully they will help resolve your issue.
