VPN connection not working anymore
YY09
Hi
I use Cisco AnyConnect to connect to my employer's VPN. Since few days ago, I cannot connect anymore. It still works normally on any other network (public wifis, other broadband connections etc.).
I've tried the "Low" and "Off" settings for the firewall in the Member Centre and in my router - but to no avail.
What else can I do?
1 REPLY
caravanj
Re: VPN connection not working anymore
@YY09
Even if you don't use IE make sure the proxy box in IE is unchecked & then try to connect.
