VPN- Router access
pleasenlighten
VPN- Router access
Hello,
I am looking to use a VPN service ,but need to know if my Router supports a `consumer based VPN service`.
The Router I have is a Netgear N150  WNR 1000v3 Plusnet.
Thanks FH
Fixes: 192
Re: VPN- Router access
if the VPN is software based that runs on your PC it will be fine.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
pleasenlighten
Thanks dvorak
