VMBU problems again (17/8)
rhohne
Anyone else noticed that the VMBU is not updating correctly.
So far my peak usage today is 250K, also around lunchtime my off-peak usage incremented.
Do PN actually know what is causing the update scripts to crash and what steps are been taken to make the system more resilient?
Fixes: 4
Re: VMBU problems again (17/8)
Usually my VMBU is affected when others report that there is a problem, but mine looks about right today  Huh
Mayfly
I haven't had a reading since peak time started on Thursday morning. The usage chart has been updating properly for weeks.
jamesanstee
My usage seems to be showing correctly .
rhohne
Recorded usage is still way out for today
@rhohne
I'm presuming your usage was higher? I'll get this looked into.
@Mayfly
Yours now looks like it's generating OK.
rhohne
My usage is normally in the region of 5GB to 7GB per day, not the smaller values shown over the weekend in the VMBU
Today's VMBU usage has been incrementing all day, but has some way to go to match today's estimated usage which is so far currently about twice my normal usage.
On the 16th & 17th there were two files(one hour's worth each) that had not reported correctly, this would have contributed towards the lesser amount showing over the weekend.
Keep an eye on your usage ov3er the next couple of days and we'll take another look if it doesn't seem correct.
RobPN
Seasoned Pro
Fixes: 4
FWIW I'm on "Unlimited" (the one which started last Dec.)
My usage is showing;
No off-peak usage for the 12th.
No usage at all for 14th - 17th inclusive.
No off-peak usage for the 18th.
All incorrect (not that I'm bothered).
