VMBU Confused?
- Re: VMBU Confused?
VMBU Confused?
21-12-2009 8:50 AM
Not certain whether this means PN are giving me more free usage or taking some away
Doesn't really make much difference to me - but there does seem to be a problem someone might want to look at.
Message 1 of 4
(1,066 Views)
3 REPLIES 3
Re: VMBU Confused?
21-12-2009 10:00 AM
Very strange, I wouldn't worry about it at the moment. I'll keep my eye on it to see if anyone else is saying the same and get a problem raised if so.
Message 2 of 4
(382 Views)
Re: VMBU Confused?
23-12-2009 2:35 AM
Note sure if it's relevant but I sometimes see weird figures at the beginning of the month. Here's a shot of my VMBU figures just over two hours after this months rollover. I've no idea where the 13.05GB comes from It always sorts itself out so it's not critical just a bit peculiar if you catch it.
Message 3 of 4
(382 Views)
Re: VMBU Confused?
23-12-2009 9:19 AM
VMBU can look a little strange on your billing day, as there are a couple of scripts that run at different times.
Message 4 of 4
(382 Views)
