VDSL with Draytek 2850
- Re: VDSL with Draytek 2850
18-01-2012 9:32 AM
Just received a Vigor 2850n to go with my FTTC service from Plus.Net.
It took an email to Draytek to find this out, so I wanted to make it more visble.
(Draytek publish instructions for the V2750 here: http://www.draytek.co.uk/support/kb/kb_vigor_v2750_setup.html)
The key information you need is that the VDSL service needs a VLAN Tag of 101.
You'll find the VLAN setting on WAN\General Setup\WAN1: set VLAN Tag insertion (VDSL) to 'enable' and enter a Tag Value of 101.
Of course, you have to enter your <username>@plusdsl.net and password (in WAN\Internet Setup\Internet Access: WAN1 Details Page).
Doing both of these from factory-reset gets my VDSL connected.
As far as I can tell, these settings will work for VDSL from other providers (including BT).
4 REPLIES 4
18-01-2012 5:19 PM
Message 2 of 5
(2,494 Views)
20-01-2012 7:46 AM
Hi Adam,
Just for curiosity, was the issue of this Vigor 2850n VDSL2 modem a one-off replacement for the Huawei HG612 FTTC modem as usually provided by BT Openreach for FTTC services via Plusnet, or are you now issuing them for use with all new Plusnet FTTC services?
Paul.
Paul.
Message 3 of 5
(2,494 Views)
20-01-2012 9:57 AM
We don't supply Draytek routers so it won't have been from us.
I think the OP meant that they'd received the router from elsewhere to go with the FTTC service from us.
Quote Just received a Vigor 2850n to go with my FTTC service from Plus.Net.
Message 4 of 5
(2,494 Views)
20-01-2012 10:45 AM
Quote from: _Adam_Walker_ We don't supply Draytek routers so it won't have been from us.
Ah. My misunderstanding.
It was just that the Vigor information link stated that it could be used IN PLACE of the HG612...........
Paul.
Message 5 of 5
(2,494 Views)
