VDSL wiring
rbel
VDSL wiring
Is there likely to be any discernible difference in performance between the following two setups:
i)  NTE5 > supplied lead to BTOR modem >12 metres of cat5E > billion 7800n
ii) NTE5 > 12 metres of cat5E > BTOR modem > billion 7800n
wykehamhouse
Re: VDSL wiring
i) This is the better option and the speed will be (potentially) better with this. Whether it will make any difference, I cannot say. However, if you can, choose option i.
rbel
Re: VDSL wiring
Many thanks for the quick response.  If BTOR supply their optional extension kit where does that fit in?
wykehamhouse
Re: VDSL wiring
OR will do option i.
NorthEasterner
Re: VDSL wiring
May I say in (ii) Its not CAT5E cable from NTE5 its a standard RJ11 cabling not ethernet.
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
rbel
Re: VDSL wiring
I have an existing 12 metres run of cat5E from near to the NTE5 to another NTE5 type socket adjacent to the current modem's position so I was thinking of just linking the second NTE5 and the modem together using an RJ11 lead.
