VDSL routers for FTTC?
toolateforaname
Could I ask for peoples experiences with VDSL routers to replace *both* BT boxes?
Searching around gives me conflicting info about which devices work without the BT modem and given that these are not cheap...
It would be nice to have a list of devices together with info about firmware versions and config settings to get them working with plusnet FTTC.
I understand that there are :
Draytek 2760n 2860
Fritzbox 7390  7490
Asus  DSL-N66U
Asus DSL-AC68U
Cisco 887VA ISR
HH3
HH5
Billion 8200
Technicolor  TG589
TechnicolorTG672
Any others?   what problems have people had configuring them?
Thanks HM and Andy, et al
Phil - you're right I meant the 8200
55 REPLIES 55
HairyMcbiker
All Star
Fixes: 21
Re: VDSL routers for FTTC?
The HH3 doesn't replace the modem it just has a wan port to connect to it.
The TG589 is another to add to your list, I have been using one for several months now, not a bad router, 1000% better than the 582. Missing dual band and Gigabit ports though.
AndyH
Asus DSL-N66U and DSL-AC68U
pjmarsh
Fixes: 20
The Billion 7800 doesn't.  It's that same Hairy McBiker says about the HH3.
Phil
DaveyH
Champion
Fixes: 12
Quote from: AndyH
Neither of those have a VDSL modem do they?
npr
Fixes: 9
Technicolor TG672 does VDSL.
It's a obsolete business class router, occasional pops up on ebay.
30FTTC06
Fixes: 4
What is the Asus DSL-N66U?
Do you remember the Asus RT-N66U? It is arguably the best performing dual band 802.11n router currently on the market and predecessor to the superb 802.11ac compatible RT-AC66U. Now Asus is expanding the 66U brand again with a VDSL2 modem packing version of the N66U that is compatible with the latest fibre optic broadband standards.
Read more at http://www.trustedreviews.com/asus-dsl-n66u_Peripheral_review#JTsB4zMqBPJLuIQU.99
tijara33
Fixes: 6
The Asus DSL versions of the 66 & 68 do have a built in modem. Don't confuse them with the RT versions.
The excellent  AVM Fritz!Box 7490 doesn't require a modem but it's not cheap.
http://www.trustedreviews.com/avm-fritz-box-7490_Peripheral_review#tr-review-summary
For further options, please see below.
http://www.ispreview.co.uk/index.php/2014/01/broadband-router-options-uk-fttc-isps-integrated-vdsl-m...
mrcoyote
There's also the Cisco 887VA ISR, but it's not cheap at around £300 inc VAT.
toolateforaname
Quote from: mrcoyote
Whats the story with cisco and running costs?    I seem to remember that they wanted to charge a support fee for access to patches and licences and so on?
toolateforaname
Quote from: tijara33
Thanks !    That ISP review is a good article
mrcoyote
Quote from: toolateforaname
I guess it's more they're aimed at the enterprise market where it's more common to have support contracts, etc in place.  To your average home user it's a complete overkill, but to businesses where a device can cost in the many thousands, a few hundred for patches, etc is nothing.
highfield5
Another possibility is the (newish) ZyXEL VMG8324-B10A.
I only bought one last week, so it's a bit early for any definite conclusions as to how good it is, but it's not looking too bad at the moment.
Costs around £100
Ian
toolateforaname
Thats irritating - I cant edit the first post anymore  Sad
I was thinking tht it would be handy to have a list and then fill in features and details of any specific set up needs...
Routerconfirmed working on plusnet FTTC
Asus DSL-N66UY
Asus DSL-AC68U
BT HH5
Billion 8200
Cisco 887VA ISR
Draytek 2760
Draytek 2860
Fritxbox 7490
Fritzbox 7390
Technicolor TG589Y
Technicolor TG672
ZyXel VMG8324B10AY
gwillym
BT HH5 also confirmed as working on Plusnet FTTC = had mine since Feb and no problems so far
