Usual download speed query!!
- Usual download speed query!!
Re: Usual download speed query!!
10-03-2013 5:49 PM
Run the BTw Test again using the original computer and check the results.
The improvement might be due to the fact that you've resynced the Modem
10-03-2013 9:35 PM
10-03-2013 11:37 PM
You could check that the computer with the slow speedtest has the latest drivers for the Network Interface Card.
10-03-2013 11:52 PM
You were right, just pinged ntp.plus.net.
Quote Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Cholek>ping ntp.plus.net
Pinging ntp.plus.net [212.159.13.49] with 32 bytes of data:
Reply from 212.159.13.49: bytes=32 time=13ms TTL=250
Reply from 212.159.13.49: bytes=32 time=12ms TTL=250
Reply from 212.159.13.49: bytes=32 time=17ms TTL=250
Reply from 212.159.13.49: bytes=32 time=14ms TTL=250
Ping statistics for 212.159.13.49:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 12ms, Maximum = 17ms, Average = 14ms
C:\Users\Cholek>
11-03-2013 1:41 AM
I'm surprised anything that's new enough to be running Vista is having speed problems like that, but I'm no expert on that.
If you fancy giving your brain a workout, have a read of http://www.speedguide.net/articles/windows-7-vista-2008-tweaks-2574 ; I don't know if there's anything useful there for you.
11-03-2013 2:20 AM
11-03-2013 10:58 AM
11-03-2013 4:46 PM
I have today done another speed test 1 week on, the only thing I have noticed is that the max achievable has dropped from 48.6 down to 42! 1meg a day!
? I will carry on keeping an eye on it to see if it falls any further
11-03-2013 5:02 PM
12-03-2013 6:36 AM
Quote from: Anotherone But if you want to be happy, then remove the lower faceplate but not the top vDSL plate and leave the modem plugged in undisturbed.
One day I would like to move my master socket, but you mentioned that I should not be touching Open Reach plate.Engineer who installed the modem said I will have no problems moving it if I want to. So is it possible or not? I would have to disconnect it to move the socket. Is there a procedure to do it, so I will not mess up with my IP profile?
12-03-2013 9:27 AM
12-03-2013 10:59 AM
12-03-2013 11:18 AM
12-03-2013 1:34 PM
12-03-2013 3:00 PM
Can you see the cable outside where it goes into the wall? What does it look like - is it black and round about 5.3mm in diameter?
