Usual BT speedtester question
- Usual BT speedtester question
09-02-2011 4:06 PM
Just checked BT speed tester and its LP is 6500kbps?
Your DSL Connection Rate :8131 Kbps(DOWN-STREAM), 1107 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
Router stats
Uptime: 6 days, 19:22:22
Modulation: G.992.5 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 1.107 / 8.131
Speedtester issue or stuck profile ?
Ticket #39705700 just in case
Thx f9o
Re: Usual BT speedtester question
09-02-2011 10:25 PM
Your routers uptime may be 6 days but your connection isn't I'm afraid...
Jojo
09-02-2011 10:39 PM
Nothing in the router log.....hmmm
Is that chart showning dropped PPP sessions instead of dropped sync ?
A snap shot of the speedtouch
Thanks for taking a look
09-02-2011 10:44 PM
09-02-2011 10:54 PM
Looking one the Speedtouch's PPP internet connection information it says uptime 1day , 0:08:53
which would tie in with at last dropout on the chart yesterday evening around this time frame ?
thx f9o
Snap shot
11-02-2011 12:53 PM
Can not seem to find any resyncs below 7392Kbps in the past 9 days .....lowest seems to be the 8087 ( current sync )
I'm on the DLM trail, so it kind of defeats the object of it , if the put through is stuck at 6500Kbps?
Thanks f9o
11-02-2011 4:55 PM
Still a lot of drops. I've not put them in the graph as you can't see all the drops that were close together.
00:55 11/Feb/2011 N/A 15:53:46 (on going)
13:04 10/Feb/2011 00:53 11/Feb/2011 11:49:43
22:42 08/Feb/2011 13:03 10/Feb/2011 One Day, 14:21:38
22:41 08/Feb/2011 22:42 08/Feb/2011 0:0:9
22:41 08/Feb/2011 22:41 08/Feb/2011 0:0:16
22:39 08/Feb/2011 22:41 08/Feb/2011 0:1:36
13:01 08/Feb/2011 22:39 08/Feb/2011 9:38:8
13:00 08/Feb/2011 13:01 08/Feb/2011 0:0:56
12:57 08/Feb/2011 13:00 08/Feb/2011 0:3:18
12:17 07/Feb/2011 12:57 08/Feb/2011 One Day, 0:39:47
19:14 05/Feb/2011 12:17 07/Feb/2011 One Day, 17:2:25
19:14 05/Feb/2011 19:14 05/Feb/2011 0:0:13
19:14 05/Feb/2011 19:14 05/Feb/2011 0:0:8
19:14 05/Feb/2011 19:14 05/Feb/2011 0:0:5
19:13 05/Feb/2011 19:13 05/Feb/2011 0:0:10
19:13 05/Feb/2011 19:13 05/Feb/2011 0:0:5
19:13 05/Feb/2011 19:13 05/Feb/2011 0:0:9
19:08 05/Feb/2011 19:13 05/Feb/2011 0:4:48
19:08 05/Feb/2011 19:08 05/Feb/2011 0:0:6
19:07 05/Feb/2011 19:08 05/Feb/2011 0:0:9
19:07 05/Feb/2011 19:07 05/Feb/2011 0:0:5
19:07 05/Feb/2011 19:07 05/Feb/2011 0:0:12
19:06 05/Feb/2011 19:07 05/Feb/2011 0:0:33
20:45 02/Feb/2011 19:06 05/Feb/2011 2 Days, 22:21:19
Jojo
11-02-2011 6:09 PM
Its easier for me to check......
The speedtouch only says auth session drops, not sync (*apart from that last one at 00:55) 11/Feb/201 which is a nuisance to try and get a handle on things as the likes of routerstats doesn't not highlight any issues
Looks like its a case of test another router & take things from there.
Thanks again for taking the time to look
f9o
*DSL Connection
Link Information
Uptime: 0 days, 17:16:38
Bandwidth (Up/Down) [kbps/kbps]: 1.083 / 8.087
24-02-2011 1:33 PM
BT LP is now 7150kbps
However speed tests seem locked at 6500kbps. Stuck Plusnet profile ?
Ticket # 40181521 just in case.
Those radius charts really help.
It would be great if the customer could access/generate the charts themselves, say under connection settings for example?
Thanks f9o
24-02-2011 5:16 PM
What throughput are you getting?
Jojo
24-02-2011 5:40 PM
BT's LP 7150
http://www.speedtest.net/result/1172239440.png
Earlier
http://www.speedtest.net/result/1171891856.png
Tried MTU/rein as another option, but its the same at 1430 or 1500
Thanks for the chart !
#40181521 just in case
25-02-2011 2:57 PM
I've just had a look at the speed test from yesterday and the throughput was 6762k so it's definitely on a 7150 profile.
Jojo
25-02-2011 3:23 PM
The put throught "feels" stuck at 6500.
Both Speedtest.net & MyBroadbandspeed gives the same at verious times during the day/night.
Could the hard profile thats set on the line something to consider or something obvious that i'm missing?
Thanks for taking at look, its appreciated !
f9o
25-02-2011 4:33 PM
You'd never get 6499 throughput on a 6500 profile.
Jojo
25-02-2011 4:45 PM
Reminds me very much of old Plusnet bug of a stuck 2500kbps line profile even though it said different in connection settings.
Since the the hard profile line set i can't seem to get put through above 6500kbps (speedtest/mybroadband ect) dispite a synce over 8300 which as you say would give 7150 put through.
I could try & step the sync up over 9088kbps and see what happens ( it would be pushing things on the snr but its forcast settled weather)
Any other ideas or something to try would be most welcome
Thanks again f9o
