Ustream tv won't work on new plusnet fibre
Nathbax
Hi having recently gone from adsl to fibre I am unable to use ustream tv on anything ipad iPhone and ps4 . It worked fine on adsl . Every since fibre install a few weeks ago I'm unable to use it. The only way around was to install a VPN app on my ipad. Ps4 has twitch and ustream. Twitch is instant but ustream won't load. Any ideas
Nathbax
Re: Ustream tv won't work on new plusnet fibre
Anyone have any issues with ustream on plusnet fibre? I having to use a VPN to get it to work
Fixes: 305
Welcome to the forum Nathbax, I've got ustream working in the browser ok and installed the iPad app and that's ok as well.
That's on PN unlimited fibre.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Plusnet Staff
Plusnet Staff
Fixes: 5
I've not heard of any issues with ustream to be honest.
Have you got it correctly configured on your end?
Chris Pettitt
Cloud Environments Engineer
Nathbax
That's what I'm wondering. But what should I need to configure. I've no issues with anything else working. It's baffling me. I'm running a asus n66u router. Did try the plusnet supplied one but that didn't work either.
Plusnet Staff
Plusnet Staff
Fixes: 5
Do you need to forward any specific ports on the Asus router?
Chris Pettitt
Nathbax
I wouldn't  have thought so else surely it wouldn't work when I use a VPN would it? I
theropers
I cant get it to work on my samsung smart tv
just get please wait......
Dont know if its a plus net thing or a samsung thing..
