Using the BT Home Hub with PlusNet Broadband service
- Using the BT Home Hub with PlusNet Broadband servi...
09-01-2009 10:05 PM
1) Does this work with the Original V1.0 Home Hub and if so, what level of firmware is required
2) Do V1,5 and V2.0 of the Home Hub also work?
3) If connected via PlusNet, will the Firmware still auto-update as it does with BT?
4) Can the BT Hub Phone be used on both POTS and VOIP?
Re: Using the BT Home Hub with PlusNet Broadband service
09-01-2009 10:09 PM
http://community.plus.net/forum/index.php/topic,72595.0.html
09-01-2009 10:39 PM
I never did get an answer but I think Dave Tomlinson may be able to shed som light on this.
09-01-2009 10:43 PM
09-01-2009 11:28 PM
Plusnet have trialled TR69 on the new Thomson Router to allow automatic firmware updating, but there is still a lot of work to do before it can become a formal product.
Maurice
10-01-2009 12:01 AM
Quote from: pierre_pierre From what was said last week, in two threads, the BT Home hub can not be used on the PN ISP
The homehub will work as a router on a plusnet connection, I know as I have tried a v1, a v1.5 and a v2.0 on plusnet and f9 accounts. You cant use things like the VOIP side as its locked to the BT services.
A friend of mine uses a homehub 2.0 as his router on his f9 account simply for the powersave feature to turn of the wireless when its not needed.
10-01-2009 12:06 AM
10-01-2009 12:41 AM
10-01-2009 12:58 AM
10-01-2009 8:28 AM
03-02-2009 8:08 AM
Quote from: pierre_pierre that didnt come up in the discussion this week, I cant find the particular thread, but I think it was that the Current Hubs are locked to BT, Best of Luck
Not true, I am a Plusnet customer using a BT Home Hub v2 with no issues. There are very cheap on eBay so i bought one. I full expected to have issues but was looking forward to the challenge of making it work. Imagine my disappointment when I logged on the the hub's web interface and simply entered my Plusnet log on infomation. The wirelass range is so much better than my Netgear... 🙂
03-02-2009 10:47 AM
So they've found a workaround for the later versions now then?
I don't have one, just interested
03-02-2009 12:29 PM
