Using my Broadband Premier at two locations
- Using my Broadband Premier at two locations
30-05-2008 12:43 PM
Re: Using my Broadband Premier at two locations
30-05-2008 12:48 PM
The CLI is in reference to dialup access
30-05-2008 12:51 PM
30-05-2008 1:06 PM
When a line is activated for broadband it has a realm allocated in BTs system which allows you to connect to a service provided by a company.
Typically the PlusNet realm is plusdsl.net (although others have been used in the past and are valid, also others may be used for the other vISPs too - but I don't know those off the top of my hat.)
So; the only place that you can log onto a broadband connection using your PlusNet credentials is if the physical line has the same realm attached to it as your account.
I have a broadband line at home, and at work - both of which are part of the @plusdsl.net realm. Each line has its own account and associated subscription fee's etc, and if I desire I could connect at my work location using my home location credentials.
There is little point though, as to have the realm in place at work, there has to be an associated account - so thats the one logically used to connect at work.
Ignoring then the fact that it *is* possible, its not really practical as very little is gained. (Other than the ability to utilise two sets of download allocation across both sites - if I used all the included GB on my home account, I could then use my work account to continue downloading stuff instead of buying additional GBs, but really its only a theoretical gain.)
The simple answer is that its not something you can do.
The CLI numbers refer to using the dial-up capabilities of your account to connect via a 56k modem. You could use this to get internet access whilst at work, but you must bear in mind that connecting via dialup will disconnect your broadband router as you can only be logged in at one place at one time.
30-05-2008 1:16 PM
Reading your much more detailed reply a question springs to mind.
If you have two accounts an expensive high usage account and a £9.99 Option 1 account could you use the high user account on either connection providing you only used it at one place at a time.
30-05-2008 1:20 PM
30-05-2008 1:25 PM
30-05-2008 1:26 PM
@Mogie - if you're going for BBYW option 1 with home phone we will install the line for you and you won't have a BT account - we'll be looking after everything to do with the line. You won't be able to get BT to install a line without signing up to a contract with BT, iirc this is for 18 months.
Hope that helps,
30-05-2008 1:29 PM
Some providers like mine 3 offer some accounts for 50% off. mine costs me £7.50 per month for 3GB and I got a free usb modem for my laptop it will work in a desktop computer too.
Puddy
30-05-2008 1:36 PM
30-05-2008 2:07 PM
The other option is to use your mobile as a modem to access the internet, depend on your handset whether you can do this. On the website they have this as £1 per day, but normally a download limit apply but I cannot find this. You only pay when you access the internet. In the past I have used this option when my landline broadband have been down.
Edit:
Quote Data Charges
Unless a data or BlackBerry Bolt On is taken, your tariff will include O2 Web Daily under which data will be charged at £3 per MB up to a maximum of £1 per day (00:00am to 23:59pm). Once you have reached your maximum daily charge of £1, O2 Web Daily allows you unlimited use of O2 UK‘s Edge/GPRS/ 3G networks (as applicable to your handset), for personal internet use via your mobile phone. All usage must be for your private, personal and non-commercial purposes. You may not use your SIM Card:
in, or connected to, any other device including modems;
to allow the continuous streaming of any audio / video content, enable Voice over Internet (Voip), P2P or file sharing; or
in such a way that adversely impacts the service to other O2 customers.
If O2 reasonably suspects you are not acting in accordance with this policy O2 reserves the right to impose further charges, impose network protection controls which may reduce your speed of transmission or disconnect your tariff at any time, having attempted to contact you first.
Data usage is measured in kilobytes (KB). 1MB = 1024 Kilobytes (KB), 1024 MB = 1 Gigabyte (GB). If Data usage is less than £1 it will be rounded to the nearest kilobyte on a daily basis, and charges are rounded up to the nearest 1p. You are billed for the amount of data that travels over the data network. Please note that your bill may include charges for re-sent data packets and packets added to control the flow of data over the network.
The prices shown do not incorporate data roaming rates.
30-05-2008 2:15 PM
Quote from: Oldjim James,
Theoretically, yes.
I doubt PN would be bothered these days because of how the network is managed to ensure that bandwidth is available, although I recall there might be a clause somewhere about not using residential products for businesses and vice-versa. (Again, thinking back it could be because of certain assumptions about the likely times of day the bandwidth would be consumed by each account type.)
Since the last few product refreshes, and taking into account the way the PN manage the network these days, I doubt there would be an issue really either way.
If you were considering an example of say, a holiday home used some weekends and holidays, and a usual place of residence through the week - it could make perfect sense to have a BBYW Pro account at one address, and a BBYW 1 account at the other, changing the credentials over so that the one you are physically at is the one with the higher priority profile attached.
Taking the example further; if you use voip you could essentially have the same number whether you were at home or at the holiday home too without much effort.
30-05-2008 2:40 PM
I am sat in my office at home, with my PlusNet connection @ 3.5M, when I turn around to use my work laptop I will enjoy 7.2M mobile broadband from Vodafone.
So landline broadband is not necessary faster.
30-05-2008 2:53 PM
Edit: Okay just visited Vodafone website and see that that 7.2M is available in certain post codes in London and at airports. Have checked this out before as I'm with Vodafone but forgot.
30-05-2008 2:59 PM
you dont need a land line because it use a mobile phone signal.
puddy
