Using broadband service in different location
Debbiem01
I have moved to look after my Dad, he has virgin media package, no broadband. Is there anyway I can use my plusnet broadband elsewhere, thanks
4 REPLIES 4
Legend
Fixes: 253
Re: Using broadband service in different location
Welcome to the forums, @Debbiem01 . Unfortunately PLusnet doesn't work on a Virgin circuit - the technology is totally different.
If your dad has VM TV, though, does he not have a modem/router as part of the package?
Legend
Fixes: 253
Sorry - I did not know - until I've just checked - that VM did TV only packages. I'm afraid in this case, the only option would be to get a BB package with VM. You could then use that.
Debbiem01
Thank you for this information. There is a Samsung box, I will contact VM to see if they can add broadband to the package
Debbiem01
Thank you, I will try that
