Using a Linksys EA6900 router with plusnet
- Using a Linksys EA6900 router with plusnet
01-03-2014 10:00 PM
Hi, new to the forum. Wanted to have better wifi ac performance as have a macbook pro. Unfortunately I am unable to get internet to work with the Linksys EA6900 router (worked well for the first hour or so and then stopped), has anyone else tried this router with plusnet and has it worked? Thanks
Message 1 of 2
(667 Views)
1 REPLY 1
Re: Using a Linksys EA6900 router with plusnet
03-03-2014 3:09 PM
Hi lightchain,
I don't have any personal experience with this router to be honest with you. I can see you're currently connected, does that mean that you managed to get this router working or are you using a different one?
Message 2 of 2
(359 Views)
