Using TG582n with Apple Airport Extreme
- Using TG582n with Apple Airport Extreme
10-04-2013 8:59 AM
I wish to use my new Technicolor TG582n Plusnet Modem/Router with my Apple Airport Extreme Wireless Router, ie use it only as a Modem.
I understand the TG582n wireless router side can be switched off using the Wi Fi switch on the unit. Has anybody had any problems with this configuration?
Also, what is the WPS switch on the TG582n used for?
Message 1 of 5
(2,390 Views)
4 REPLIES 4
Re: Using TG582n with Apple Airport Extreme
10-04-2013 10:51 AM
The information posted here should help you get going with that: http://community.plus.net/forum/?topic=112632.msg966406
In case you're not aware WPS means WiFi protected set up and is intended to be an alternate method of connecting wireless devices:
http://en.wikipedia.org/wiki/Wi-Fi_Protected_Setup
Quote what is the WPS switch on the TG582n used for?
Message 2 of 5
(553 Views)
10-04-2013 3:42 PM
Poll removed as it served no purpose
Message 3 of 5
(553 Views)
10-04-2013 4:36 PM
Adam, I think he's talking more about using TG582n in bridge mode and having the AirPort handle DHCP/NAT? I started a thread explaining how to do it once, let me find it...
Edit: Here we are. http://community.plus.net/forum/index.php/topic,111711.msg957655.html#msg957655
Message 4 of 5
(553 Views)
10-04-2013 4:39 PM
Found the link!
Message 5 of 5
(553 Views)
