Using Sky router
- Using Sky router
Using Sky router
30-05-2015 9:42 AM
I am not using the router what Plusnet provided me with as we found the WiFi part pretty poor, i am using a Sky router. Is this why my usage stats don't update on my account.
Message 1 of 4
(2,798 Views)
3 REPLIES 3
Re: Using Sky router
30-05-2015 12:20 PM
It looks like your connecting to Sky rather then ourselves at the moment which is why your usage isn't showing.
As far as I'm aware you can't change the details in the Sky router so you wouldn't be able to use it with ourselves.
Did you try changing the wireless channel on our router to see if that improved things?
http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml
Message 2 of 4
(2,243 Views)
30-05-2015 1:28 PM
Hi Matthew. No i haven't tried changing the channel, i will look into trying it out. Is there any problems if i keep this Sky router going as i do get slightly faster speeds only slight though and the WiFi part is much better.
Message 3 of 4
(2,243 Views)
30-05-2015 1:41 PM
Message 4 of 4
(2,243 Views)
