Using 2704n router for fibre contract
- Re: Using 2704n router for fibre contract
31-03-2020 12:44 PM
I was meant to receive a visit from an engineer to set up fibre in my new home yesterday. As for covid19 advice, I was meant to receive updates if that had to change. No visit and no update but ok.
I am desperate for WiFi so my question is, will I be able to use my old ADSL router from the previous house once my service becomes active (hopefully) tomorrow?
Thanks,
Bartosz
31-03-2020 1:02 PM
@Surek25 Welcome to the forum.
Sorry no, they do not work on fibre.
31-03-2020 2:38 PM
It's possible that your installation has been delayed and Plusnet have failed to advise you. Put your phone number in here and read through the response. Look for a mention of an open order and it's programmed completion date. If so then this will be the date that Openreach have currently planned to complete your connection. Plusnet normally send out routers to arrive just before this date. https://my.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
31-03-2020 3:17 PM
Rather disappointing I cannot simply get a date from CS, but I guess worst comes to worst I am still within contract cancellation period.
But anyway, thanks again and hopefully that check works.
31-03-2020 4:35 PM
That's not good. You need to currently have a phone number for this to work. Do you have a BT telephone socket in your new home? Even if it's dead you might still be OK. If you need to have one fitted then you're going to be disappointed as Openreach will no longer enter your property to install one until this is all over, currently until June but subject to review.
31-03-2020 5:50 PM
There is already an openreach branded socket here, so I don't think an engineer is absolutely necessary? The previous tenants also had Virgin fibre installed but I am aware this is a different type of installation.
When I said I am not sure of the landline number, it is because I don't know a way to check what it is without using a home telephone to call my mobile!
Thanks for trying to help and I hope this clarified...
