Using 2 Routers
- Re: Using 2 Routers
Using 2 Routers
26-01-2011 10:53 AM
I am hoping somebody may be able to help.
I am using a Netgear Dg834N at home and I am very happy with it, however as I am a gamer and want the best connection possible I have it plugged in direct to the main socket in my home.
This happens to be in my home office, which is a converted cellar and therefore a dead spot with regards to wireless signals. So effectively nobody in the rest of the house can get a wireless signal.
Now my question is, I also have a Netgear DG834. Is it possible to connect this router to the DG834N using a long Ethernet cable so I can put it upstairs, so effectively using it as a wireless extension.
If this is possible please could somebody explain how I configure either/both of the routers.
As both have the default IP address (192.168.0.1) would I have to change one, set up the routers differently etc etc.
Any help would be very much appreciated
Re: Using 2 Routers
26-01-2011 11:53 AM
With regards to configuration...
The router plugged into the phone line can stay as 192.168.0.1 and set up to act as a DHCP server, with starting address of 192.168.0.3.
The other router could have a static IP of 192.168.0.2 and act as a DHCP client. Set up the wireless and it should all work perfectly.
Re: Using 2 Routers
26-01-2011 12:03 PM
B.
Re: Using 2 Routers
26-01-2011 12:13 PM
I do also have one of the Plusnet Thompson wireless routers.
Would it be possible/better to use that?
So the router I have plugged on to the phone line (the netgear dg834N) can stay the same... but he second router needs to be set at as DHCP client only and I would not have to change the IP as it would be different from the other Netgear router (being the Thompson one)?
Re: Using 2 Routers
26-01-2011 12:16 PM
http://is.gd/I90MlV
Re: Using 2 Routers
26-01-2011 12:17 PM
Quote from: Barry Yup, ensure the DG834 has the DHCP server turned off, and is not plugged into a phone line and it effectively acts as a Wireless Access Point
B.
Sorry, but is there an issue that both have the same defualt IP 192.168.0.1? Will I have to change one? If I try to get in to the set up page it keeps trying to log me in to the second (DG834) rather than the DG834N
Re: Using 2 Routers
26-01-2011 12:26 PM
Quote Sorry, but is there an issue that both have the same defualt IP 192.168.0.1?
Yes, as suggested earlier you should change the DG834 to something like 192.168.0.2 , in the same subnet ( 192.168.0.x ) but out of the DHCP range of the primary router.
Re: Using 2 Routers
26-01-2011 12:59 PM
Quote from: MisterW
Great, thanks.
But being a bit of a noob could you explain how I go about doing that?
Ok so I make sure the DHCP client it switched off on the second router, then I change the deafult of that router form 192.168.0.1 to say 192.168.0.99?
And to do that I go into the second router set up and maually give it that IP address? Do iahve to change the Subnet (255.255.255.0) or anything?
Re: Using 2 Routers
26-01-2011 1:40 PM
Do the setup on each by connection directly to the router with a lan cable without the other router being connected
DG834 (this one is connected to the Phone Line)
In Lan IP setup -
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
DHCP: Yes
Starting IP: 192.168.0.10
End IP 192.168.0.254
DG834N
In Lan IP setup -
IP address: 192.168.0.2
DHCP: No
Then connect them together and see how it goes
Re: Using 2 Routers
26-01-2011 2:54 PM
I will give that a try
