Username showing
- Re: Username showing
Username showing
17-02-2017 8:27 AM
I have a static IP address with Plusnet as I need this for work. However, on many websites they are able to track IP address which then displays my Plusnet username, which is actually my full name!
I have spoken to Plusnet who have said they can remove or at least remove my full name from this, however they have not done so.
Anyone any idea on how I can stop this happening, of course I'm aware that my IP address will be visible to others, I just don't want my full name broadcast around the world!
Many thanks indeed,
MO
17-02-2017 11:44 AM
If you fill in the request here (requires login) it should be picked up fairly quickly.
I changed mine from username.plus.com to the IP address format 81.174.xx.yy.plus.com last year and it was acted on within a couple of hours,
17-02-2017 12:48 PM
brilliant, thank you I have completed this form… Let's see what happens 🙂
18-02-2017 5:27 PM
That's been put through for you, should take effect within the next 24 hours.
