Username showing as Hostname
NiM
Hi, for some reason my IP's now displaying my PN Username as my Host on lookups,  which isn't something I want.
I've had this issue before, the last time it happened I'd been randomly assigned a static IP (I should be on a dynamic), not sure if that's the case again this time?
I'd appreciate it if someone could sort it out, thanks.
1 REPLY 1
Fixes: 1,620
Re: Username showing as Hostname
If I'm looking at the right account, you've had a static IP since 2016. You able to PM me your username to confirm?
