Usenet still up the spout after upgrades.
- Usenet still up the spout after upgrades.
Re: Usenet still up the spout after upgrades.
01-04-2008 9:40 PM
01-04-2008 9:44 PM
Quote from: vibes
Quote Anybody that still cant get in should go to http://www.plus.net/suppo...em.php?intProblemId=50908 and click This problem is affecting me.
Ok jelv have done that , is it working for you yet?
Sorry this page could not be found
01-04-2008 9:47 PM
01-04-2008 10:02 PM
Quote from: jelv Click the link in my post, not vibes quote of my post.
Got that, thanks
But it tells me nothing more than here. ?
Still cannot get in .
01-04-2008 10:09 PM
01-04-2008 10:13 PM
If so, is it not a fairly simple exercise to compare the two IP lists rather than use a webform to ascertain who can and who can't access giganews. The latter is not going to be anywhere near the true figure since many may not have attempted to use the news server.
FWIW I am still seeing error 480 - auth required and yes, I've added my username on the webpage.
Hopefully it will be sorted by tomorrow morning. That gives them another working day to sort it out.
01-04-2008 10:55 PM
I have added all your IPs to the problem so we can pick this up first thing tomorrow. Incidentally, most of them appear to be in the 87.xxx.xxx.xxx range and are dynamic. You might be able to work around the problem by activating a static IP via the member centre (BBYW customers).
01-04-2008 10:57 PM
Quote from: Appoloin Now plus net are using giganews does this mean we got binaries again.
No. Binary groups are not carried by the PlusNet servers.
Quote Usenet now is working for me. The only strange thing is if all the articles have been renumber Thunderbird hasn't noticed. But I have notice there does seem to be more spam on this server.
The article numbers for Giganews were higher than the Supernews ones. Both the following reference the same post:
Xref: sn-us uk.telecom.broadband:240710
Xref: number1.nntp.dca.giganews.com uk.telecom.broadband:263606
01-04-2008 11:06 PM
Vibes
01-04-2008 11:12 PM
No need to renumber as far as I can see with my client, looks clean.
I'll probably wait a bit to move others on to Giganews, had enough hassle for now.
01-04-2008 11:17 PM
01-04-2008 11:21 PM
Quote from: Bob
Supernews servers did, the headers weren't available but if you sent the message id the server would supply the article. Unfortunately that technique isn't working giganews
01-04-2008 11:44 PM
Surely Plusnet know their IP ranges to forward onto 3rd party suppliers
02-04-2008 12:38 AM
Quote from: waynepyrah How did this happen in the first place???
Yes we do. The problem stemmed partly from the fact that our Madasafish reseller account was already with Giganews. MAAF customers share some of their IPs with PlusNet users and Giganews' systems didn't accommodate for a permitted netblock to coexist across more than one reseller account
Giganews finally managed to sort this out (or so we thought) but it appears that there may still be an issue with some netblocks.
Quote from: Appoloin Supernews servers did, the headers weren't available but if you sent the message id the server would supply the article. Unfortunately that technique isn't working giganews
And there's me thinking that nobody had cottoned on! I'm guessing that was you on our Ellacoya graphing then?
We helped mitigate the potential impact of this by restricting each thread to 64kbps.
Supernews didn't offer a strictly text only package whereas Giganews do, this is why you can't do it anymore.
02-04-2008 12:54 AM
- sn-ip.vsrv-sjc.supernews.net - asks for username & password, then "A News (NNTP error occurred: Access Denied via @ auth server"
- plusnet.vsrv-ams.supernews.net - "Could not connect to server plusnet.vsrv-ams.supernews.net; the connection was refused"
- news.plus.net - "Could not connect to server news.plus.net; the connection was refused"
- usenet.plus.com - "Failed to connect to server"
I have tried both OE on a clean installation on my laptop as well as a fresh install of Thunderbird: both have failed on all four server names.
I remain quite able to access forums.projectseven.com, news.microsoft.com and news.mozilla.org on OE, so this is clearly not a local issue. Having checked thoroughly, there does not appear to be any reference to any PlusNet news server in any file on either my desktop or laptop.
