Usenet - authentication required
- Usenet - authentication required
30-11-2009 12:29 PM
I am now seeing 'authentication required' errors on two usenet clients on my Mac and one client on RISC OS using PlusNet's servers.
Is anyone else?
Is anyone else?
Message 1 of 5
(1,656 Views)
4 REPLIES 4
Re: Usenet - authentication required
30-11-2009 1:03 PM
It's working fine for me, not requesting authentication and allowing me to get the full list of groups.
Is your newsgroup client set up to send authentication and are you currently on a Plusnet connection?
Message 2 of 5
(583 Views)
30-11-2009 1:27 PM
Two of the clients were already set up and had been working. The new client, Unison, was correctly set with the username and password fields blank.
I have rebooted my router and it is working now! I am not sure whether that makes any sense.
Thanks for responding.
Message 3 of 5
(583 Views)
30-11-2009 3:31 PM
You'll get authentication errors if you exceed the maximum allowed number of simultaneous connections from the same IP address. Are all these machines connected to the same router? I think the connection limit is currently set to around six threads.
Message 4 of 5
(583 Views)
30-11-2009 4:48 PM
Quote from: Bob You'll get authentication errors if you exceed the maximum allowed number of simultaneous connections from the same IP address. Are all these machines connected to the same router? I think the connection limit is currently set to around six threads.
That's it, Pan on Linux defaults to four connections and I now think the maximum is three, so once Pan is running nothing else is going to get a look in. With both Pan and Unison set to one each both clients can run concurrently, not that that is what i want to do in the longer term I was just looking for the best usenet client.
Many thanks for the pointer.
Message 5 of 5
(583 Views)
