Usenet Speeds
tomxlisa
Usenet Speeds
Got a slight issue, getting good speeds on http://www.speedtest.bbmax.co.uk/ but slower than normal speeds using usenet, what could this be, could this be plusnet slowing me down, even though its gone 12am, as i see from http://usergroup.plus.net/prodcomp1.php the priority for it is bronze, but never had a problem with the speeds after 12 until now?.
tomxlisa
Re: Usenet Speeds
Just tested torrents and got full speed on that. Roll eyes
Fixes: 10
Re: Usenet Speeds
I think you may be looking too soon after midnight. Loads of extra traffic kicks in at midnight as people take advantage of the free overnight. You should find speeds increase over the next hour as the downloads complete and more capacity comes free. Did you recheck the Usenet speed at around the time you found the torrents were giving full speed?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
tomxlisa
Re: Usenet Speeds
Yeah i did, i checked both torrent and usenet one after the other, i think i found a solution though, i just used more connections and it then maxed out my line, the thing is i've been using 3 connections for ages now and it has been maxing out my line, but not last night for some reason. Undecided
prichardson
Re: Usenet Speeds
Depending on who you take your Usenet service from, most recommend a minimum of 8 threads as part of their diagnostics on slow speeds.
Due to the bi-directional nature of Usenet (many requests for smaller chunks down a single connection), multiple threads are recommended. I would actually recommend more than three by default.
tomxlisa
Re: Usenet Speeds
I am using 6 now and that seems to have done the trick, how many do you normally use, if you use usenet that is?.
prichardson
Re: Usenet Speeds
I originally only used 4 myself. However I have a speed restricted Usenet account, so maxing the connection was never on the cards or my intention. This did give me variable speeds and could not consistently reach the products (Usenet product, not DSL) limit.
After attempting to raise a support ticket with my Usenet provider, their support troubleshooter made the recommendation of a minimum of 8 threads. I now consistently reach the products intended limit.
I do now have other Usenet troubles, though I have linked some of them to my router, the rest linked to the supplier (consistent reports of my issues within their support forums). So currently looking to change supplier anyway.
tomxlisa
Re: Usenet Speeds
Who do you use now?.
