Usenet Speeds
- Re: Usenet Speeds
Usenet Speeds
06-06-2012 12:33 AM
Got a slight issue, getting good speeds on http://www.speedtest.bbmax.co.uk/ but slower than normal speeds using usenet, what could this be, could this be plusnet slowing me down, even though its gone 12am, as i see from http://usergroup.plus.net/prodcomp1.php the priority for it is bronze, but never had a problem with the speeds after 12 until now?.
Message 1 of 8
(1,359 Views)
7 REPLIES 7
Re: Usenet Speeds
06-06-2012 2:07 AM
Just tested torrents and got full speed on that.
Message 2 of 8
(649 Views)
Re: Usenet Speeds
06-06-2012 9:20 AM
I think you may be looking too soon after midnight. Loads of extra traffic kicks in at midnight as people take advantage of the free overnight. You should find speeds increase over the next hour as the downloads complete and more capacity comes free. Did you recheck the Usenet speed at around the time you found the torrents were giving full speed?
Message 3 of 8
(649 Views)
Re: Usenet Speeds
06-06-2012 9:53 AM
Yeah i did, i checked both torrent and usenet one after the other, i think i found a solution though, i just used more connections and it then maxed out my line, the thing is i've been using 3 connections for ages now and it has been maxing out my line, but not last night for some reason.
Message 4 of 8
(649 Views)
Re: Usenet Speeds
06-06-2012 2:02 PM
Depending on who you take your Usenet service from, most recommend a minimum of 8 threads as part of their diagnostics on slow speeds.
Due to the bi-directional nature of Usenet (many requests for smaller chunks down a single connection), multiple threads are recommended. I would actually recommend more than three by default.
Message 5 of 8
(649 Views)
Re: Usenet Speeds
06-06-2012 2:12 PM
I am using 6 now and that seems to have done the trick, how many do you normally use, if you use usenet that is?.
Message 6 of 8
(649 Views)
Re: Usenet Speeds
06-06-2012 2:20 PM
I originally only used 4 myself. However I have a speed restricted Usenet account, so maxing the connection was never on the cards or my intention. This did give me variable speeds and could not consistently reach the products (Usenet product, not DSL) limit.
After attempting to raise a support ticket with my Usenet provider, their support troubleshooter made the recommendation of a minimum of 8 threads. I now consistently reach the products intended limit.
I do now have other Usenet troubles, though I have linked some of them to my router, the rest linked to the supplier (consistent reports of my issues within their support forums). So currently looking to change supplier anyway.
Message 7 of 8
(649 Views)
Re: Usenet Speeds
06-06-2012 2:22 PM
Who do you use now?.
Message 8 of 8
(649 Views)
