Usenet CRAWLING this morning
- Usenet CRAWLING this morning
10-08-2009 11:02 AM
I was getting 50Kbs yes 50k bytes dialup speeds on 2 diferent gateways this morning both lo0-plusnet.pte-ag1.plus.net & lo0-plusnet.ptn-ag2.plus.net were VERY slow.
Now on lo0-plusnet.pte-ag1.plus.net and it seems to be about 2Mb lower than it should be.
I should be seeing full speed until 12pm. So what is happening? More cricket in the rain?
Message 1 of 5
(908 Views)
4 REPLIES 4
Re: Usenet CRAWLING this morning
10-08-2009 12:02 PM
I've just got home this morning and I'm getting full line speed on pcl-ag04
Paul
Paul
Message 2 of 5
(457 Views)
10-08-2009 12:08 PM
Well I tried changing 6 times and kept getting the same g/w so stayed on ag1, now dropped to 512Kb as expected, but should have been faster this morning.
Message 3 of 5
(457 Views)
10-08-2009 3:12 PM
That happened to me the other day I couldn't swap gateways for some reason I tried 4 times in the end I did a soft reboot of the router made a cuppa and reconnected and it had changed, I think you have to leave a bit of time before you reconnect, better to do a soft reboot than a complete one as the exchange will see frequent disconnections and lower your sync, it is a pain though trying to find a good gateway
Message 4 of 5
(457 Views)
10-08-2009 4:01 PM
Yes at NO point did I reboot the router, I only disconnected & reconnected the ppp session.
Message 5 of 5
(457 Views)
