Use current modem and router with upgrade to fibre (no phone line). Discount for not taking hub?
tonycollinet
Currently on FTTC with phone line. Just about to "upgrade" to fibre (no phone line).
I assume I can continue to use my existing modem and mesh router. If so (and don't therefore need the hub 2) is there a discount available for not taking the hub?
Ant.
4 REPLIES 4
Fixes: 99
Re: Use current modem and router with upgrade to fibre (no phone line). Discount for not taking hub?
@tonycollinet
The Hub Two is free, you just pay P&P for its delivery.
Your current device should still work
Fixes: 69
@tonycollinet
Are you upgrading to Fibre (FTTC on SOGEA) or Full Fibre (FTTP)?
Always worth taking the Hub2  for P&P only as it gives you a spare just in case.
tonycollinet
Thanks yes - I've taken the hub as a spare.
Fixes: 99
It is worth noting as you are "Just about to "upgrade" to fibre (no phone line)." the Hub two can be used in 'Bridge Mode' which makes it a modem only device.
For Full Fibre the Hub Two is not required as the ONT is effectively the modem
