Usage stats request
Razer
Usage stats request
We can all log in to the portal to view our usage for the month in more detail and the previous three generally. Is it possible that PN could provide me (privately) with my usage stats (including overnight usage) since I signed up?
10 REPLIES 10
DrDave
Re: Usage stats request
Curious - why would you want such detailed legacy info?
pwatson
Quote from: Razer
Please  Wink
chrispurvey
We'd be able to get the past few months fairly easily. Is it just the total amount of usage you need?
Razer
Hi Chris, thanks for your reply.
What I'm looking for (sent privately) is more than I can currently see by logging in to the portal (being three months of general usage). I would like to see more detailed info: data usages over as long a period as possible for upload and download, day and night (i.e. on and off tariff). If that's possible I'd very much appreciate it.
EDIT:
I am sorry, Chris. I should read and actually take note. Yes, I would like total monthly usage, but for both day and night usages shown separately, if possible. Thanks.
chrispurvey
I'll check with Dave if this is doable, it won't be until next week though as he is out of the office all week.
Razer
OK, thanks Chris.
chrispurvey
I'll try and get this data to you tomorrow Razer, I'll pop a ticket on your account with it on.
Razer
Thank you kindly, Chris.
chrispurvey
I've dropped a ticket(#75045764) on your account, I hope this helps.
Razer
Thanks once again, Chris. Very helpful.
