Usage reported by TG582n - very dodgy figures
- Re: Usage reported by TG582n - very dodgy figures
02-04-2013 11:15 AM
According to the router
Uptime: 3 days, 21:35:47
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 888 / 3.869
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,73
According to Plusnet Total about 1.9GB
Why is the router reporting masses of upstream usage
Message 1 of 7
(1,026 Views)
6 REPLIES 6
02-04-2013 5:16 PM
Message 2 of 7
(575 Views)
02-04-2013 5:32 PM
Quote from: Oldjim
Probably a software issue with the router and should say [MB/GB] 199 / 1.73
That would = the Plusnet 1.9 GB
Message 3 of 7
(575 Views)
02-04-2013 5:41 PM
Could be but I have never noticed it before
Message 4 of 7
(575 Views)
02-04-2013 7:14 PM
Mine currently says
Uptime: 10 days, 19:44:44
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.180 / 9.721
Data Transferred (Sent/Received) [MB/MB]: 634,51 / 14,66
despite 1.22GB being transferred yesterday according to VMBU. Can't verify from Networx on my PC since most of that data was to/from a non-monitored TV but the total is about right.
I think one can conclude that Data Transferred doesn't mean much.
David
Message 5 of 7
(575 Views)
02-04-2013 7:19 PM
I asked about this before and its not accurate, so not worth relying on.
FTTP 500 regrade from Tues 28th November
Message 6 of 7
(575 Views)
02-04-2013 7:20 PM
Perhaps the figure goes back to zero when it exceeds 2^31 - 1 bytes or something like that.
Message 7 of 7
(575 Views)
