Usage question
Timalay
Usage question
By how much does you speed reduce after you go over your maximum monthly spend?  Say percentage wise.
I'm getting about 12mb now
1 REPLY
CX
Re: Usage question
256kbps, if I remember correctly. A significant drop from your 12Mbps!
