Usage monitor
AceViral
Usage monitor
Can someone suggest a broadband usage monitor thats as easy and obvious to understand as the one on the View my usage page in the Member's Centre please?
Something that can sit on a desktop and simply puts a clear number of Gb over a given time.  I just want to keep a bettre eye on my usage without having to log in.
The one on the View my usage page is perfect, I'd just like it on my desktop if possible.
Cheers guys!
Fixes: 71
Re: Usage monitor
If you are using a Windows PC I suggest taking a look at Networx. You can set it to ignore local (LAN) traffic and collate measurements from multiple devices as long as they are all Windows PCs.
David
Infinity
Seasoned Pro
Re: Usage monitor
