Usage cap download speed 0.01Mbps
Ant1
I have gone over the 40gb usage cap on Fibre and I am now being capped to 0.01 Mbps and the same between midnight and 08:00
Technical; support say that although it will be capped at 256kb/s it is up to 256kb/s.
Is 256 kb/s 0.256 Mbps
11 REPLIES 11
Oldjim
Resting Legend
Fixes: 63
Re: Usage cap download speed 0.01Mbps
when I hit the cap it was 256kbps up and down - I know because I ran a speed check to test and the limit is applied 24/7
Ant1
Applying the  cap overnight does seem unfair as it is advertised as Unlimited overnight usage
Oldjim
Resting Legend
Fixes: 63
It does doesn't it but it has always been that way  Sad
Ant1
It might have always been that way but that's not what it says when you sign up.
My broadband is now virtually unusable now at 0.01 Mbps which is I believe 10kb/s
Fixes: 160
Quote from: Ant1
Hi Ant1,
Welcome to the forums.  Yes the above is correct and the "up to" caveat is the same caveat apparently applied to all speed quotes, however, I'd dispute that it applies here.
Quote from: http
If you reach or go over your spending limit, your speed will be rate limited to 256kb/s and all p2p, usenet and FTP traffic will be blocked until your next billing date.
I'd expect your synch speed should be as fast as the line will support, albeit your data speed will be limited.  Can you please post your router stats?  I suspect something else is wrong here.
Overnight usage (between midnight and 8am) does not count towards your monthly usage allowance
With the above consideration, one would not expect the restriction to apply 00-08, indeed I gave been told by support that is correct, but not found it to be the case.
Oldjim
Resting Legend
Fixes: 63
he is on fibre so no stats available
Fixes: 160
douh!  Embarrassed
Oldjim
Resting Legend
Fixes: 63
However a BT speed test further diagnostics may help
petecov44
If it works for him.
Paying the £4 a month extra ( if on ME3) would also help him as he would get unlimited)
Ant1
Here are the results from the BT speedtest
Oldjim
Resting Legend
Fixes: 63
was there a further diagnostics option as those results look very odd
