Usage allowance.v. speed. v. extra spend
- Usage allowance.v. speed. v. extra spend
11-02-2012 7:00 PM
Sorry if this has been covered somewhere, I didnt know where to begin with a search!
Ok, Im on the Plusnet Value package where I get 10GB per month usage allowance and I'm aware that if I go over this my speed drops. I've added an extra £10 extra monthly spend using the Manage My Usage facility, but what i need to know is this:
If I go over my original 10GB allowance, even though I have £10 extra spend in place, does my speed drop?
I've never gone over the 10GB but predict this could be a busy month as I have more work on than usual...I need my speed not to drop! And i'm not interested in any other packages!
Thanks! PK.
Thanks! PK.
Message 1 of 5
(883 Views)
4 REPLIES 4
Re: Usage allowance.v. speed. v. extra spend
11-02-2012 7:21 PM
No
Until you have used up your maximum monthly spend your speed isn't affected at all
Message 2 of 5
(376 Views)
11-02-2012 7:31 PM
Thank you!
Message 3 of 5
(376 Views)
11-02-2012 7:52 PM
Quote from: PeaKay I've never gone over the 10GB but predict this could be a busy month as I have more work on than usual...I need my speed not to drop! And i'm not interested in any other packages!
I know you say you are not interested in any other packages but please remember that Extra (60GB allowance, or £50 worth of 5GB addons) is only £5 a month more than Value!
Message 4 of 5
(376 Views)
11-02-2012 8:06 PM
and you are allowed to change you package up or down once a month, So that if you think you are in for a busy month, lash out the £5 and drop it the following - but remember the changes only take place on your billing day
Message 5 of 5
(376 Views)
