Usage Reporting 11-Sep
KevinG
Anyone else noticed an issue with usage reporting for yesterday? Mine is showing as 11.77MB peak whereas I must have used several GB. I suspect Tuesday 10th is significantly under-reporting as well. I'm on unlimited so I really don't care much but I like to keep track of approximate monthly usage.
Re: Usage Reporting 11-Sep
Hi KevinG,
It does seem that your usage is somewhat out to your normal usage pattern, we've currently a problem(76497) raised to investigate this. I've added your details to this and as soon as we have an update we'll provide one.
It does look since your last disconnection that your usage has been recorded ok today.
looks similar for me too...
Call me 'w23'
houlton23
Me too by the looks of it, as you can see our background usage (nothing being used) is ~250MB per 8 hours so 30MB for 16 hours definitely doesn't stack up!
Alex Smiley
Fixes: 4
Mine is missing several hundred MB during peak time on the 11th.  Undecided
I've added these to the problem raised above and will look to get an update on the asap.
