Usage Monitor Problem
Gazzer
According to the usage monitor my recent usage is far more than normal and so far this week it seems to be almost doubling on a daily basis. Looking at todays figures I don't think I would have even been connected long enough to use the volume that I apparently have.
Is anyone else having a problem with the daily usage monitor.
DavCee
Re: Usage Monitor Problem
Yes, I have had similar problems..... Now daily usage no longer working !.... failed from about 28th Oct 2014
Plusnet aware of problem.
Gazzer
Smiley Solved - I think
Looks like it may be due to Malware - ran a scan and there were a couple of things detected which have now been removed so hopefully that is sorted now.
