Usage Allowance being used up very quickly
missa3
my internet was activated last week, I am on a 60gb allowance. Have already used 20gb of this, have 2 laptops in the house. We have done a bit of downloading over the weekend with would explain some of the usage, however have not downloaded anything today and just used internet for general browsing and usage is already up to 1.3gb. Having been told that 60gb is sufficient allowance for general surfing why is it eating up my allowance so quickly? How slow will my connection be when I hit 60gb?
60 REPLIES 60
jelv
Fixes: 10
Re: Usage Allowance being used up very quickly
Do you use any P2P software? If so be aware that uploads are counted as well.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
missa3
my housemate downloads through torrents, once these are completed though they dont continue to upload (as in on the list of downloads the up speed is 0) sorry I am not very good at techology
SteveA
If you are downloading torrents then the best thing to do is schedule your torrent software to only be active between midnight and 8am as that is "free" usage.
missa3
there is no activity on the torrent programme during the day though
jelv
Fixes: 10
I suggest you install http://www.softperfect.com/products/networx/ on each PC which will show you your usage hour by hour.
I suspect you may find the torrent is active in the background.
Hary
Quote from: missa3
the up speed is 0
Isn't that unlimited. should be 1  ?
SteveA
missa3
although all the torrents were stopped we have turned off the torrent programme now so it only comes on at night time. hopefully that should work thanks
missa3
it is now at 2.2gb usage for today.. havent streamed or anything, just surfing so im guessing it is the torrent programme. If it continues to go up so fast I have no idea what it is!
ctech500
is your WIFI  secure  from unwanted "guests"  check your router's logs for any unrecognised devices
missa3
how do i check the router logs? there is a passcode for the network so i assume it is secure
missa3
8gb was used yesterday. Did not use near as much.
jelv
Fixes: 10
I'll repeat - install NetWorX - you'll instantly see if there is any activity in the background.
missa3
how much of my download allowance will downloading this programme take up?
