Urgent help with question 145311877 please!
Plusnet Staff
Plusnet Staff
Fixes: 117
Re: Urgent help with question 145311877 please!
No worries. I've been checking your fault everyday and I'm seeing it's not been assigned to an engineer as of yet. As it's still within the response time we've been given we're unfortunately not able to chase Openreach. Sad
I'm rota'd off tomorrow, but I've already passed your account to one of my colleagues to contact Openreach tomorrow and he will provide you an update via your ticket.
I'm really sorry for the length of time this is dragging on for and for the inconvenience caused.
As for your fibre activation, our suppliers have pushed this back to the 24th March due to engineer availability in your area I'm afraid. Apologies that you weren't made aware of this.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
lancem
I appreciate the response, many thanks!
lancem
Hate to say it but Fiber was activated today (email saying so at about 1am) but the old problem from last week has resurfaced somehow! We have an orange blinking light and can't even connect the router to get it set up Sad
Plusnet Staff
Plusnet Staff
Fixes: 117
I'm sorry to hear this Sad I've left the office for the weekend I'm afraid however if you private message me with your landline phone number (if you know it) I will be happy to run a few tests via our suppliers systems.
+Edit+
@lancem - Thanks for the private message. Just tested your line and I'm not identifying any problems. The router's in sync with the exchange but it's not authenticating. It's possible it's just the auto setup of the router not quite working correctly.
Are you able to access the router gateway at http://192.168.1.254, ideally using an Ethernet connection from a laptop or PC? If so, I think you'll just need to connect using your [username]@plusdsl.net and your account password.
 Plusnet Staff
lancem
I've connected via ethernet and basically i get as far as selecting the option to enter my username and password in the hub manager, but then it just says 'PPP connecting' continually. This is also the case after resetting the router a couple of times. It can't seem to pick up a connection just enough to enter the log in details! So it's stuck with the setup@plusdsl.net one and i cant change it!
Fixes: 33
I am not in front of mine now, but if you go to advanced settings. And I think broadband, press the disconnect button, and once it has you should then be able to enter your username and password, and then press connect.
If it's anything like when I first joined, it may take a few attempts.
Plusnet Staff
Plusnet Staff
Fixes: 117
Can you try unplugging the DSL cable from the router then enter your connection details, press connect then plug the DSL cable back in? This should hopefully fix the spinning PPP connecting issue.
 Plusnet Staff
lancem
I managed to get as far as entering the password about an hour ago so that's that sorted. No connection still despite trying the suggestions kindly offered above . Still just the solid orange light and the spinning icon on screen despite entering correct password.
I might give up now and try again in the morning.
lancem
Okay still absolutely nothing today and it's now been well over 24 hours since activation. I saw something in another thread with identical issue stating 'password was missing from the radius server'. Could that be the problem? I'm clutching at straws now seeing as, like you say, you can pick up the router your end.
Plusnet Staff
Plusnet Staff
Fixes: 117
Sorry to hear you still can't connect. Sad It's possible that you may be affected by the radius password issue though as far as we're aware it's just affecting new customers.
I'll check up on things for you Monday morning, apologies if you don't manage to fix it over the weekend.
 Plusnet Staff
lancem
Thanks buddy, still ongoing today! I'll leave router switched on tomorrow for any tests etc. Have a good weekend​! (What's left of it)
Fixes: 33
You could just give them a call, or use chat and maybe get an answer today?
Plusnet Staff
Plusnet Staff
Fixes: 117
Thanks for your patience @lancem It looks like a cross jumpering problem as your circuit is in sync but the flashing light on the router is indicating it's out of sync.
I've updated your ticket now, if you let me know on here once you've replied I can get the engineer booked in for you. I apologise for the inconvenience caused.
 Plusnet Staff
