Upstream speed crash - reason known
- Re: Upstream speed crash - reason known
12-07-2011 4:00 PM
I was just uploading data to my website when I lost internet connection.
I have routerstats running so a quick check showed that the router had resynched with an upstream speed of 128kbps 6dB noise margin and downstream about 4450kbps (bang goes my 4000kbps IP profile)
Did a quick resync and result
Rx-Noise=6.1 Tx-Noise=7.0 Rx-Sync=4704 Tx-Sync=288
Looked out of the window and a post office van was parked under the telegraph pole and the wire to my house while the postman was emptying the post box
So waited until he drove away and then did another resync
Rx-Noise=6.0 Tx-Noise=23.0 Rx-Sync=4704 Tx-Sync=448
Can this be classed as sabotage or just a cable which isn't up to scratch
Message 1 of 7
(16,812 Views)
6 REPLIES 6
12-07-2011 4:37 PM
I wonder if we should add that question to our support pages? Is there a van parked outside?
Message 2 of 7
(630 Views)
12-07-2011 4:53 PM
LOL. Another thing that can go wrong...
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 3 of 7
(630 Views)
13-07-2011 8:53 AM
Does a diesel engine still have a distributor to kick out EMF or do glow plugs not need one?... Or am I thinking into this too much?!
Message 4 of 7
(630 Views)
13-07-2011 10:27 AM
What is the "telegraph" data rate anyway? 200 words a minute?
Now Zen, but a +Net residue.
Message 5 of 7
(630 Views)
13-07-2011 1:32 PM
did you make sure his black an white cat wasn't up the pole using it as scratching post?
Message 6 of 7
(630 Views)
13-07-2011 3:20 PM
Possibly someone was sending a large electromagnet through the post?
Message 7 of 7
(630 Views)
