Upstream currently capped - can this be removed?
Dibblah
Due to some line issues a couple of years ago, interleaving was explicitly enabled and the upstream speed was (I believe!) capped to 448kbits/s.
Would it be possible to have these removed? The line issues were caused by a noisy power pole mounted transformer near to our line, which has been replaced.
There are a couple of recent disconnects, but these were due to getting a new modem to work.
Cheers,
Allan.
3 REPLIES 3
Dibblah
Re: Upstream currently capped - can this be removed?
Specifically,
(Ignore the error counters - this is a Lantiq modem on a Broadcom DSLAM - I will be switching back to something more appropriate to the line when it arrives)
    Receive Direction Send Direction
Max. DSLAM throughput kbit/s 24384 448
Min. DSLAM throughput kbit/s 160 32
Attainable throughput kbit/s 1960 765
Current throughput kbit/s 1960 446
Seamless rate adaptation   off off
Energy-saving mode L2 off
Latency   8 ms 7 ms
Impulse Noise Protection (INP)   1.2 3
G.INP   off off
Signal-to-noise ratio dB 4 16
Bitswap   on on
Line attenuation dB 63 39
Power reduction dB 0 0
Carrier record   A43 A43
Error Counter
  Seconds With Not Remediable Errors (CRC)
  Errors (ES) Many
Errors (SES)
per
Minute
Last
15 Minutes
FRITZ!Box 36857 0 10 153
Central exchange 0 0 0 0
Beyhive
Fixes: 43
Hi @Dibblah, sorry to hear you're having broadband issues.
Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online here
Thank you for your patience.
 Faris
Dibblah
Question ID is 201125331. It's been a week since this ticket was submitted.
This is a DSL line, I'm just asking for a banding removal so DLM can start managing the line normally, rather than the upstream being explicitly limited.
The banding was added after a horrific series of events, culminating in the local energy distribution company replacing a piece of pole mounted equipment adjacent to our line.
Thanks for your help!
Cheers,
Allan.
