Uploads count towards usage limit?
JackDavidson
I'm about to set up my own web server and wondered whether uploads counted towards your monthly usage allocation? Initially I assumed that it doesn't as ISP's usually refer to the limit as a "download limit" and the vast majority of traffic is probably downloads. Although as its referred to as a "usage limit" by PlusNet it wasn't so clear.
I've been hunting round the small print but haven't found anything that spells this out, so an official answer would be great.
Thanks  Smiley
Re: Uploads count towards usage limit?
Not an 'official answer' but uploads do count towards your usage limit.
198kHz
Aspiring Champion
Fixes: 11
Yes, uploads do count, and PN certainly aren't alone in that respect. Can't think at the mo where I've seen it officially spelt out, but I'll post if I find it.
Remember you are unique - just like everyone else
198kHz
Aspiring Champion
Fixes: 11
Yer tiz
http://www.plus.net/support/broadband/usage/vmbu.shtml
Below the two screenshots.
If you are worried about your monthly usage limit  you maybe should consider changing to Plusnet's new unlimited usage product.
itsme
Are you aware of the daily allowance for website traffic? You can read about here
aren't those two different things?
I understand the OP to be thinking about setting up a webserver at home (so is wondering about whethr others downloading from his home server is seen as "uploading" on his BB usage by PN); whereas the usage limits on webspace you are linking to refers to hosting a site on PN's servers.
(i think ... )
itsme
You are right should read and engage brain and not just skim posts.
JackDavidson
wow quick replies from the community, thanks for that Smiley Seems it does count.
I'm on BBYW3 at the mo so I'll switch to unlimited, I was also thinking of increasing my upload bandwidth to 832kbps with Max Premium http://portal.plus.net/wizard/?wizard_id=20 . The site I am building is a multiblog/community site using Drupal, has anyone got any feedback about how they have found running their own webserver from their PlusNet account?
itsme
For the past 2 years I have run both web and email servers on my connection and have had no problems.
scootie
max prem is well worth the extra dollar esp if you have specific use for it.
i would check to see if your exchange is 21cn WBC enabled and maybe give the plusnet adsl2+ trail ago you will get the upload for free then.
the only downside of the adsl2 uplaod is it's a varable sync rate where max prem is fixed at 832kbps. but if your on a gd line you will get  higher up sync on adsl2 than max prem.
