Uploads count towards usage limit?
- Re: Uploads count towards usage limit?
15-03-2009 10:28 AM
I've been hunting round the small print but haven't found anything that spells this out, so an official answer would be great.
15-03-2009 10:41 AM
15-03-2009 10:42 AM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
15-03-2009 10:46 AM
http://www.plus.net/support/broadband/usage/vmbu.shtml
Below the two screenshots.
15-03-2009 11:47 AM
15-03-2009 11:49 AM
15-03-2009 12:03 PM
I understand the OP to be thinking about setting up a webserver at home (so is wondering about whethr others downloading from his home server is seen as "uploading" on his BB usage by PN); whereas the usage limits on webspace you are linking to refers to hosting a site on PN's servers.
(i think ... )
15-03-2009 12:11 PM
15-03-2009 12:39 PM
I'm on BBYW3 at the mo so I'll switch to unlimited, I was also thinking of increasing my upload bandwidth to 832kbps with Max Premium http://portal.plus.net/wizard/?wizard_id=20 . The site I am building is a multiblog/community site using Drupal, has anyone got any feedback about how they have found running their own webserver from their PlusNet account?
15-03-2009 12:51 PM
15-03-2009 5:36 PM
i would check to see if your exchange is 21cn WBC enabled and maybe give the plusnet adsl2+ trail ago you will get the upload for free then.
the only downside of the adsl2 uplaod is it's a varable sync rate where max prem is fixed at 832kbps. but if your on a gd line you will get higher up sync on adsl2 than max prem.
