Upload uncapping
- Upload uncapping
Upload uncapping
06-08-2016 5:20 PM
I've hear that if I ask for it I can get my upload speed uncapped. Is this free? Can I get my upload uncapped?
Thanks,
Re: Upload uncapping
06-08-2016 8:53 PM
Hi, I think it depends on what type of exchange you are on if it's a C21 then I think it's free, otherwise there's a monthly fee.
07-08-2016 8:05 AM
& can't be done on a CN20 exchange at no cost.
Check your exchange here:
07-08-2016 3:26 PM
Thanks for your help everyone.
My exchange is 21CN. Do I have to call Plusnet up to enquire about this then?
07-08-2016 4:38 PM
@gizmoguy - You could contact them if you want but chances are the very useful Plusnet peeps that post here on the site will pick this up for you tomorrow. They should also be able to confirm any cost that might be incurred. Give it till lunchtime then if there's no action here make your call, but I don't think that'll be needed.
08-08-2016 10:43 AM - edited 08-08-2016 10:48 AM
Just looking at this for you now.
It looks like your upload speed is already uncapped. You're syncing at about 1Mb. Are these the kinds of speeds you are seeing?
Matty
08-08-2016 6:29 PM
Hi Matty,
With speedtest.net I get between 15-16 Mbps downstream and 0.7-1 Mbps upstream. What is the expected uncapped upstream sync speed?
Line stats posted below for your information. Error count seems to be high (these stats are after line has been up just 5 minutes), but no noticable problems, so not sure what's going on there...
Upstream SNR (dB) | 7.2 |
Downstream SNR (dB) | 6 |
Upstream interleave depth | 1 |
Downstream interleave depth | 1 |
Upstream line attenuation (dB) | 6.8 |
Downstream line attenuation (dB) | 11 |
Upstream output power (dBmV) | 12.5 |
Downstream output power (dBmV) | 19.5 |
Upstream CRC | 20 |
Downstream CRC | 17 |
Upstream FEC | 13 |
Downstream FEC | 0 |
08-08-2016 7:09 PM
about 1Mb/s or a little bit higher
