Upload - uncapped?
Steevo
Upload - uncapped?
Recently moved back to Plusnet. My download speed is normal, but my upload speed is only around 0.35mbps, whereas previously I was nearer 0.75mbps. Is it possible my broadband upload speed has been capped?
5 REPLIES 5
Fixes: 1,600
Re: Upload - uncapped?
Welcome back @Steevo
If you can PM me your new username I'll be happy to look into this for you.
Fixes: 1,600
Thanks for the private message.
I've placed an order to uncap your upstream speed.
Let us know how the speeds look tomorrow.
RobC
Upload speed capped?
Whats that about?
Show us ONE just ONE real, defined benefit for the British public from Brexit
Brexit Promised cake .... But just delivers a stream of Cack
... and expects us all to just swallow it
Brexit - Built from Bovine Manure by Bots
Fixes: 159
@Gandalf,
I rather thought that uncapped US has been the default for years now?
Manual order error?
MatthewWheeler
Fixes: 479
@RobC When a order is placed on our suppliers systems there are two options for upstream (upload) speeds. These are 448kbps and uncapped
@Townman This will have been the case. It's actually the default selection on the system we use to place the orders so unless the agent changes it (which happens in most cases) it will be capped by default
 Matthew Wheeler
